Tecumseh 5hp Snow King problems
I bought my Ariens 5hp snow blower back in 96. It's been running ok since then but starting last year and continuing this year, it's been running like crap. It would do fine under no load but as soon as you put it up against a couple inches, it just bogs down severely....almost shutting off completely. I was planning on ordering a new carb for it to see if that would be the problem. Anyone have any input? Thanks
Received 2 Upvotes
Even if you aren't comfortable servicing the carburetor yourself and you're at least able to remove the carburetor from the engine, a typical repair shop charge shouldn't be more than $30 and likely will be less. That beats the average cost to replace it, being around $60.
Received 2 Upvotes
SHOULD be part #31840, kit and 33673A, gasket but post back with engine ID numbers first in order to confirm such part numbers. I'll be away for the weekend, so, if the model begins with HSSK, then this will be the kit and gasket.
