tooo much fuel
Old 12-08-05, 10:11 AM
steve3773
Unhappy tooo much fuel
my snowblower has a 5 horse techumseh, number 143-687022 and it over fuels to where it floods out before it gets started.
have used it twice this year so far, it has just started doing it. I have taken it off to make sure nothing is in it. are there any tricks and tips to help me out.
Thanks
Steve
Old 12-08-05, 01:45 PM
v8driver's Avatar
make sure the float isn't hanging up. was fuel stabilizer used? that is if it set for more then a month at a time. inlet needle may be sticking as well.
Old 12-08-05, 02:11 PM
steve3773
thanks, for the help. fuel was fresh thanks again
Old 12-08-05, 02:58 PM
puey61's Avatar
When you say it is flooding out do you mean it is a rich running condition or that the carburetor leaks when at rest? If rich, lean out the main jet about a quarter turn in. If leaking, disassemble the carburetor, soak and recondition it.
Old 12-09-05, 07:07 AM
steve3773
when I try to start it it puts too much gas in the engine and floods out the head not at rest,,,,,,,I'll try to lean it out a bit
thanks
steve
Old 01-18-09, 07:03 AM
your float is sinking. it has fuel inside so it wont rise to drive the pointed pin into the hole to stop the fuel flow so it runs out of the carb.
