Tecumseh 10 hp engine backfire
Old 12-09-05, 04:58 PM
justtony
Question Tecumseh 10 hp engine backfire
I have a Tecumseh HM100, 10 hp engine on a 5200 watt generator. A few months ago I had the carb rebuilt by a repair shop - the float had failed and fuel was running straight thru carb. Thing worked fine when I got it back and it sat unstarted for 2 months or so. When I started it today it was hard to start ( normal for this unit) and then ran terribly, backfiring constantly. Thought fuel may be bad so drained tank and installed new fuel with some dry gas. Still backfiring. Noticed if iI close choke a notch it runs a little better. What do I do next?
Old 12-09-05, 09:06 PM
v8driver's Avatar
no fuel stabilizer? probablly needs a fine tuning to the adjustment screws though. any black smoke when its backfiring?
Old 12-10-05, 05:27 PM
justtony
Doesn't Have Any Adjustment Screws...one Screw Seems To Be A Needle Valve Of Some Kind But Doesn't See To Do Anything With Engine Running. It Is Turend In Tight And Sealed In That Position. Don't See Much Smoke.
Old 12-10-05, 06:35 PM
v8driver's Avatar
wheres that screw located at? anyway, does it have a in-line fuel filter? i'd take the fuel line off at the carb, crimp the line, let it go in a can or something, making sure its getting fuel. if it does blow any smoke, is it black or a whitish blue? black is indeed a rich condition, white would be just oil. could've gotten trash in the carb as well.
