Snowblower Help Needed 5 hr. Tecumseh
Old 12-15-05, 10:36 AM
I cant get any "spark" out of my Tecumseh 5 horse engine. Anybody have any ideas as to where I should start? I removed the plug then I reinserted into the plug wire. No spark when I pull the starting cord. Help!
Old 12-15-05, 02:35 PM
puey61's Avatar
If it's old enough to have points then you likely need to replace such as well as the condensor. If not that old then check for any bare spots in the ground (kill) wire as it is rare for these ignition coils to fail...but they do on ocassion. Post back with your engines' ID numbers and we'll be better able to help you.
Old 12-15-05, 04:07 PM
This is a dumb question I know. Where are the points located?
Old 12-15-05, 05:18 PM
v8driver's Avatar
under the flywheel, flywheel will have to come off of course. just get new points via a online source or a small engine shop, make sure you have all your info on the engine to give em to get the right parts. also you'll need a puller to safely remove the flywheel.
Old 12-16-05, 03:40 AM
puey61's Avatar
Engine ID numbers please, first and I'll let you know if you, in fact, have points.
Old 12-16-05, 10:18 PM
cheese's Avatar
Are you making sure that the spark plug is touching a metal part of the engine when you check for spark? If it isn't, then it won't spark.
Old 12-17-05, 02:09 PM
Yes the plug was touching metal. Where are the engine numbers located?
Old 12-17-05, 11:42 PM
usually stamped on the cowling and painted over--but you can see em.
Trackbacks are On
Pingbacks are On
Refbacks are On
