Two Cycle Governor Problems
Old 12-22-05, 02:02 PM
Rick Spalding
Engine runs wide open....the governor arm does not move to close the throtle at all. If I manually move the arm the RPM 's are steady and clear...the arm stays in full open position...is there something inside that could be broken??
Engine in question is a Tecumseh HSK 845 Two Cycle on an MTD Snow Blower.
Old 12-22-05, 05:00 PM
v8driver's Avatar
all the linkage is hooked up correctly? everything is the same as it was? then yeah the governor could, not be working
Old 12-23-05, 03:03 AM
puey61's Avatar
If the throttle shaft is not varnished (frozen) in place then it likely is an internal problem with the governor.
