Should I Sharpen Chainsaw?
Got a MacCat 2.3ci. I'm sure that having a pro sharpen chain is best.
But between visits to him, do you recommend my doing it? If so,
what is best way to do it?
Received 2 Upvotes
Sure, you can absolutely do the job yourself! Ideally, you'll want a vice to sturdy the saw in. Then you'll need a file/guide combo sharpener. This helps you do the job correctly. You may also want to purchase a depth gauge and file in order to file the depth gauges properly as well. Check with your local saw shop for these tools. Or check out Oregon products website.
I recommend a sears electric sharpner, it looks like a dremel tool. I'd touch up blade every two tanks, takes minutes, and you will never make sawdust.
Don't need a pro with this tool, the tool is the pro.
