Snowblower engine size compatability
I would like to know what size/family engines are compatible to use to replace a 8HP Tecumseh snow king model#HM80-155361N, Ser#8245R. It is on a 88/89 Simplicity 860. I haven't removed it yet, so I don't know any of the engine specs-Shaft size,etc. I am hoping to go bigger(maybe 13HP) Any info/help would be greatly appreciated.
Received 2 Upvotes
The engine mounts the same on a 13 horse as does an 8 horse. The only difference there might be (and i'm unsure since I don't currently have a 13 horse on hand to measure) is the height at the center of the crankshaft, although I believe they're the same.
The shaft height on HMSK80-110 are the same 4.176". I think the larger engines are 4.4 or 4.6. Changing shaft height on a snow blower is not fun, and results in non-standard belts, etc.
I think the large B&S Intek Snow wngines have the correct shaft height, but have a different mounting pattern. That's pretty easy to accomplish.
Most on-line vendors have line drawings, and also have notes, like "Shaft height is 4.17". Mounting holes will have to be redrilled if you are replacing a Tecumseh engine."
I called Tecumseh and B&S customer service when I wanted to replace an old Tecumseh H50 on an old Ariens. Tecumseh was helpful, B&S was really helpful and even sent a data sheet on what was required.
I have purchased a 11HP Briggs Snow Engine(couldn't pass up the deal!!) to replace my old 8HP Tecumseh Snow King. I have been told by more than one dealer who sell Simplicity that they use either engine interchangeably when one supplier can't meet their needs. I am hoping that the swap won't be a NIGHTMARE. The things we do for MORE POWER?!
Some Simplicity machines had brackets and/or mounting holes for both, so you may luck out. Drilling new monuting holes is about as easy as it gets. You can buy spacers if the B&S is too low.
The older Ariens machines had a straight chute crank that doesn't work with OHV engines. I bought some u-joints and routed it like the newer models. Doesn't sound like you'll have that issue to face.
