Ariens ST824 8hp Engine Problem
I have an 8hp Tecumseh on an Ariens ST824 SnowBlower. The problem is that the bolt ear on the block that the carb manifold attaches to broke off.
I guess my question is, Has anyone ever run into this problem an fixed it ??? This is a very strong engine and I would hate to have to replace the block/engine because of this problem.
Received 2 Upvotes
Of course, stay tuned for anyone that has been in this situation and repaired such AND it has worked. I don't think you should "repair" it even if someone tells you they could. It's the intake and if it isn't done properly then you will develop a lean condition and this is not good for an internal combustion engine. Eventually, if indeed lean, you will burn the components in the combustion chamber and likely even more damage could be sustained in the crankcase. The only part you would need to replace is the cylinder block (and of course related gaskets) but may elect to install a shortblock, depending on the age of the engine.
There is a low temp aluminum brazing rod that could be useful. The problem with replacing just the block is landing up with used parts failing and setting you back to square one. A short block is a better choice for repair.
Since replacing the entire engine is half the price of a new machine, it is a hard decision to make. But being from very frugel stock myself, I think you have very little to lose by trying to repair your motor. After all, it is basically junk now.
Originally Posted by 99venomsvt
This is exactly what I was thinking. This engine is unusable in the state it sits now. I will see if I can get an ear TIG welded back on, then drill and tap. I guess this is my best solution for cheap. Thanks
Received 2 Upvotes
If you elect to have it TIG'd professionally AND you have to pay full-shot for such (in other words, you don't have a friend in the business) AND you may need to pay to have it drilled and tapped (bolt hole center to center is somewhat critical) then you need to add up these costs versus the cost of a new block which is typically around $185. BTW, a shortblock is around $265. These prices are general and not specific to your engine since you didn't post a model and specification number of your engine.
Awsome! Wish we had a local welder/fabricator that had those prices.
Thanks to everone, this board is really a help when you really need some answers.
