Craftsman Snow Thrower
gradwvu's Avatar
02-12-06, 04:31 PM   #1
I own a Craftsman Snow Thrower 4 horsepower 4 cycle engine 21 inch single stage auger propelled. The recoil starter rope on the Briggs & Stratton motor, suddenly, will only pull out about 6 inches and then it is stopped abruptly with a clank sound when it stops. Really aggrivating with the BLIZZARD we had today in the NE
Question: What might have happened? How difficult is it to repair something like this? Any suggestions?
THANK YOU!
Doreen
v8driver's Avatar
02-12-06, 05:59 PM   #2
about how old is it? try and take the shroud off, make sure the engine spins alright by hand when you do, sure it will, if its old enough to have a starter clutch, make sure it only spins in one direction and will catch, if it doesn't, then its onto the recoil itself, one simple thing that can happen, is that the rope skips over and catches between the shroud and the pulley.
gradwvu's Avatar
02-12-06, 06:12 PM   #3
It is 1 year and a half old. (dec 04)
THANK YOU
cheese's Avatar
GA
02-12-06, 11:58 PM   #4
Is it out of oil? Was it running fine before it was put up for storage? Make sure the unit is not engaged, and any belts that shouldn't be engaged are not stuck in the pulley.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
puey61's Avatar
NY
02-13-06, 02:56 AM   #5
Is this a 2 or 4-stroke engine? I've never seen a Briggs powered Craftsman 2-stroke and I know you noted it was a 4-stroke but this is odd for a single stage unit, although not impossible. Post back with the chassis' ID numbers as well as those of the engine.
