5 HP Craftsman Snow Blower
I have a 5 HP Craftsman Snowblower . It runs ok when idling ...but as soon as you put a load on it........i.e. SNOW, ......it bogs down and stalls out it doesn`t have the ooomph anymore to throw snow. Is it an engine problem ?loss of compression?, or is it maybe a clutch problem. Could anyone advise me towards a solution? Thanks ,Bill Connelly
Received 2 Upvotes
Generally, with snowthrowers, the carburetor is to blame. You may need to remove such and recondition it with the correct OEM repair kit and gasket(s). When is the last time the machine was used? Has it sat for an extended time? If so, the carburetor likely has varnish build-up and will need to be soaked in a quality bath type cleaner prior to the recon.
