Brigs Starter motor magnet came loose
rcg's Avatar
03-06-06, 04:07 PM   #1
rcg
My push lawn mower with electric start wont start using the electric starter (12 volt). It turns out that one of the permanant magnents came loose from the housing. what kind of glue should I use to put it back on and I'm not totaly sure which way it goes in the housing. How do you tell which way it goes back in? Thanks RCG
JLOpower's Avatar
03-06-06, 05:57 PM   #2
The original adhesive probably left a mark where the magnet was attached. Reattach with a thin layer of two part epoxy. Don't clamp too tight or you will break the magnet.
rhytonen's Avatar
WV
05-21-13, 08:43 AM   #3
I also have a broken starter, When the original starter (which lasted THIRTY YEARS on this 10hp Tecumseh-powered ancient Craftsman/Murray rear engine rider) finally shattered a couple of magnets, I bought a new (Chinese) replacement. Two years later the robot spot welds on the bracket came loose and now I'm considering carefully (TIG) rewelding those spots, and/or more places.
If that doesn't work or warps the case I'll try migrating the new magnets and armature into the old (VERY sturdy, US-Made) case. I had assumed magnet mounting would be difficult to impossible. It would be interesting to see how this previous poster made out!
One has to wonder at this point how good the Chinese epoxy is. But I happen to kNOW those magnets are ALL very fragile, powerful, and difficult to manage even in pieces, inside a steel case, and may not be removable in one piece.
