Stihl Blower
Old 03-08-06, 03:34 PM
zekester
Stihl Blower
I have a Stihl model BG75 (1.55 CID) engine leaf blower which doesn't want to run at full speed. I put fresh gas mix (50-1) in it, replaced the plug and air cleaner. It idles OK. The carb has two screws--one marked L and the other LA which are apparantly fro idle adjustment only . Any ideas how to get it to run at high speed?
Old 03-08-06, 09:12 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
You'll probably need to disassemble and clean the carburetor. Generally, if the carb has 2 screws side by side, the one closest to the air intake side of the carb is the high speed adjustment.
Old 03-09-06, 05:54 AM
zekester
I'll try that. I just found the owners manuel and it states that there is no high speed asjustment.
Old 03-09-06, 09:14 AM
zekester
FYI
After a little investigating, I found the spark arrester all carboned up. Cleaned it and now runs good.
Old 03-10-06, 12:30 AM
cheese's Avatar
Great! Glad you got it, and thanks for the update!
Old 03-11-06, 04:27 AM
puey61's Avatar
Received 2 Upvotes on 2 Posts
The screw marked "L" is the low speed fuel adjustment needle and the one marked "LA" is the idle speed screw. You have a fixed high speed needle...no adjustment...EPA emissions regulations.
