MTD Shredder Issue
LawnDude's Avatar
03-12-06, 02:31 PM   #1
MTD Shredder Issue
I have aquired an MTD Shredder with a 5HP Briggs. The engine is Damaged internally. I am attempting to get the shredder Blade removed to gain access to the engine so I can assess the damage.. The bolt that bolts the blade to the shaft has been removed. My question is How do you get the blade/Rotor off? (about 14 inches Dia). Do you use a Puller? I heated it with a torch but it won't budge. Help!
THanks in Advance.
LD
puey61's Avatar
NY
03-16-06, 10:14 AM   #2
I'm not absolutely certain, but I believe the engine has a keyed shaft (as opposed to tapered) and therefore merely needs to be pulled off all the way. I've never removed one so I can't imagine a puller large enough to do the job. Good luck and let us know how you make out and how you accomplished it.
