Hooking up alternator to battery.
I have a 12 1/2 hp briggs & stratton and there is 2 wires from the alternator. 1 black, for the lights and 1 red for the battery charging. I was looking for parts on ebay and found a regulator for a briggs & stratton, do I need this? Or do I just put the red wire right to the battery?
Thanks for everyones help so far.
Received 2 Upvotes
True, but, make sure the diode is in place first. If you merely have just the two wires from the alternator and not the connector (with two short pigtails and corresponding colored wires) attached to such then it will send AC current to the battery. Make sure the diode is there. This engine has a dual circuit, low voltage, low amperage charging system and does not require a regulator. It is a 14V AC, 2-4A DC unregulated system. The diode harness (pigtail) is part number 393456.
There is a plastic clip they go into, the black wire is just a wire but the red has a lump under some shrink wrap right above this clip. I'm guessing that this is the diode?
This is the same engine we discussed in the last thread, right? I told you about the lump (shrinkwrap) diode in the red wire, and you said it was there? In this thread: http://forum.doityourself.com/showthread.php?t=256270
Your answers are already there.
