Oil leak
Old 03-14-06, 08:26 PM
Oil leak
My lawn mower is a briggs and straton 20 hp v-twin cylinder which i have and oil leak that hapend last year. but it isn still run able it goes through and half a quarte of oil in about twelve hours of run at half or full throtle. the seal are replaced what should i do to fix this. it also has a desent oil burnig smell in the exhust. it also is coming from a back houseing plate near the sterring grear!
Old 03-14-06, 09:04 PM
v8driver's Avatar
About where is it coming from exactly?
Old 03-14-06, 10:15 PM
cheese's Avatar
Can you see the leak? Where?
Old 03-15-06, 03:43 AM
puey61's Avatar
Is it an opposed twin or a V-twin? On the V's, they are overhead valve and the head gasket could be the trouble. You may need to thoroughly clean the engine and run and watch to see exactly where it is coming from. Post back with the engines' ID numbers so we can better help you out. Model, Type and Code.
