how do I set valves
Old 03-16-06, 03:58 PM
how do I set valves
I have a one piston small honda engine on a generator. I had to replace the plate that the push rods went through under the valve cover. I took it apart and it went back together fine but it wont run and I assume it is because I need to set the valves. What is that procedure? thanks. Steve G.
Old 03-16-06, 11:48 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
Set the engine to TDC (piston at the topmost point of travel on the compression stroke) and loosen the locknuts/set screws that hold the adjuster nuts in place, and adjust valves to spec, tighten locks, and recheck.
