Unloader Valve
Jack B.'s Avatar
AL
03-18-06, 02:46 PM   #1
Unloader Valve
Could someone tell me the correct way to adjust the unloader valve on a pressure washer. Water keeps squirting from the relief valve (4050 psi). The pump is a GP (General Pump) #TP2530.
cheese's Avatar
GA
03-18-06, 10:42 PM   #2
I'm not sure how yours is made specifically, but most are basically the same principle. If it is not unloading when it should, it is either sticking/binding, or the spring tension needs to be backed off. Some don't have adjustment screws, and a washer or shim can be removed from the backside of the spring. Some don't have any shims, and are non-adjustable. If this is the case, then yous is sticking/binding for some reason. I have had to polish them with rubbing compound before to get them to quit sticking.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
flopshot's Avatar
03-19-06, 05:04 AM   #3
the correct proceedure requires a 5000 psi gauge and a T manifold. using the 0 degree tip, usually red, run the machine and adjust to max pressure as indicated my the mfg
output>-----<"T">----< tip >--->
l
l
(gauge)
