Oil leak
Anil's Avatar
03-19-06, 03:36 AM   #1
Oil leak
I have a mulcher which is equipped with Briggs & Stratton Single Cylinder L Head 4 cycle engine model number133432 Type 0041 Code 95051107. It is running OK and no smoke is generated but the oil is leaking. I have put the new brether but the problem continues. Would appreciate if someone could guide me with the problem
v8driver's Avatar
03-19-06, 04:45 PM   #2
Exactly where is it leaking from? Around the breather? Try to snug things up a bit all away around, if that doesn't fix it, don't use any stop leak stuff, get the gasket replaced.
michaeljp86's Avatar
MI
03-19-06, 06:29 PM   #3
If the engine is greesy like all mine then clean it all up and watch for where it coming from.
puey61's Avatar
NY
03-20-06, 07:58 AM   #4
Areas likely to leak on a horizontal shaft engine: Sump gasket; crank seals; oil drain.
