engine failure when turning
Old 04-03-06, 05:44 AM
N
Question engine failure when turning
ive just finished upgrading my go kart going from a 3.5hp to 6.5 hp engine, everythings working fine, however when turning to the right causes the engine to fail and stop working, engine in question is a 6.5 hp dek,(or D J) engine horizontal shaft, its basically a chinese copy of a honda engine, i had no problems with the 3.5 hp honda it previously had,
the new motor is mounted on a slight backward angle (which is different then the 3.5), i can pull hard left hand turns with no problem, its just when u turn right with even a small amount of speed, slow crawl speed is fine
plenty of fuel in it as well.
the only thing i can think of is when turning right the fuel is sloshing up against the side of the float messing round with it, but i didnt think that would matter since theres not much fuel and only a small area for it. any ideas as to wats the problem
regards
Old 04-04-06, 06:02 PM
P
Received 478 Votes on 439 Posts
I have seen some engines/carbs. act funny when the engine is mounted with a 5 degree angle and have real roubles when run at a 15 degree angle. The angle of your engine the g-forces in the turn and where the float is hinged can make a difference.
You can add a fuel pump and a different carb (diaphram style).
The float position in the carb can be sensitive to mounting the engine on an angle. You can try adjusting the float position to live with the engine angle but I don't have any ideas to help with turning right. Adjusting it to turn one direction only is easier.
Old 04-04-06, 09:47 PM
cheese's Avatar
Received 30 Votes on 25 Posts
It's probably a carb problem as mentioned, but another thing to check is the low-oil sentry if it is so equipped. The oil could be sloshing away from it, and it could be killing the ignition because of it.
Old 04-05-06, 04:16 AM
N
thanks
thanks for that, ill have a play around with it tomorrow
cheers
Old 04-06-06, 03:39 AM
N
thanks cheese, disconnected the oil alert and its running fine now, just have to keep an eye on the oil level now
Old 04-06-06, 11:01 PM
cheese's Avatar
Great! Glad we could help!
