substituting a carb on my Shindaiwa T-20 trimmer
Old 04-05-06, 06:38 PM
I may be able to buy a Walbro WZ-34 carburator at a low price and from a photo it looks identical to the original carb (WZ-8c) on my Shindaiwa T-20 trimmer. Does anyone know if I can make this switch or where I would find a substitution table.
I've been looking at the Walbro carb website and comparing the parts list from these two carburators. Many/most of the parts are the same, like the metering diaphram...but some that might be crucial are different (ie: the "spring-metering lever" and the "needle-power").
The WZ-34 is used on a Tanaka 20cc straight shaft brush/grass cutter and the WZ-8C is used on my Shindaiwa 20cc straight shaft, so that part is close.
Does anyone have any knowledge of this kind of switch?
jc
Old 04-06-06, 02:56 AM
puey61's Avatar
Received 2 Votes on 2 Posts
I compared the two in my Walbro manual and I'd say you can make this swap without any trouble. They both have the same size venturi and the only noticeable difference is, as you have pointed out, the spring. I don't know the tension difference but you may want to use the spring from the original carburetor.
Old 04-12-06, 07:29 PM
R
Not trying to hijack a thread,but where is a good online site to find parts for trimmer.My father-in-law gave me his dad's (now deceased) old t-20.I'm needing the fuel tank and air filter assembly.
thanks,
the rubes
Old 04-13-06, 01:49 AM
A good starting point is googling "shindaiwa parts". Then you can probably get a parts breakdown at shindaiwa.com. Take the parts number to your local lawnmower shop and they can probably order them for you, if they don't already have them. Or try the many online parts vendors. Or try eBay.
jc
Old 04-13-06, 01:51 AM
Puey61, thanks for making the comparison. I took a chance and bought the carb ($15 on ebay including shipping) so I'll find out the hard way if it works.
jc
Old 04-13-06, 02:45 AM
puey61's Avatar
Your welcome and let us know how it turns out.
Old 06-07-12, 09:39 AM
substitue for wz-15
I have a wz-15 and want to substitue it with a wz-8, will this work for me?
jbcarey
