Husqvarna 55 won't start
Old 04-06-06, 01:59 AM
Bought it in lowes a year go now won't start ,Changed coil still hard time starting Any help
Old 04-06-06, 03:50 AM
puey61's Avatar
Well without much history to go on, you need to check for the following: Sufficient spark at the plug; Sufficient compression; And, proper fuel delivery to the cylinder. Most likely it is the latter. I'd start out with flushing out the old fuel mix from the tank as well as your supply can and starting with a fresh batch, mixed properly. And I highly recommend using synthetic oil. There are other areas that could need inspection but since it is basically new, we won't get into this.
