old mtd riding mower electric starter sticks
Old 04-12-06, 04:04 PM
msidan's Avatar
I just bought a 1984 mtd riding mower. It starts and mows great.
I only have one problem. Occasionally the electric starter sticks which means when I turn the key and don't let it start and then turn the key off, the starter keeps spinning. The only way to make it stop is to disconnect the battery.
Could it be a bad key switch?
The engine in this mower looks newer than the original engine.
Other than this, the mower runs excellent for being over 20 years old.
Old 04-12-06, 07:27 PM
v8driver's Avatar
Have about the same vintage in a murray... still has the original 8hp briggs!, 1980... needs a new transaxle but the other day I was charging the battery in it (gets used once a month to every other) then went to start it and did the exact same thing, little tapping on the key switch and wiggling of the connector and back and fourth with the key, it stopped...
A new key switch is something to try, not expensive either.
Old 04-12-06, 10:29 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
It could be the keyswitch, but I think every time I have had this happen, it was because of a sticking starter solenoid.
Old 04-13-06, 06:38 AM
msidan's Avatar
starter solenoid?
Thanks for the replys. However Im not shure I know what a starter solenoid is.
Old 04-13-06, 11:29 AM
v8driver's Avatar
The solenoid has a cable from the plus side of the battery to one post on it, and another cable on the other post to the starter, the negative should just be grounded to the frame. I do agree, it could be a sticky solenoid. The starter solenoid cuts on and off power between the cable when you turn on and off the key.
Old 04-13-06, 03:11 PM
puey61's Avatar
Received 2 Upvotes on 2 Posts
It's always nice to determine the exact cause of electrical trouble but the two items in question which could be the cause cost very little to replace. The solenoid - about $12 and the ignition switch - about $10. It is, however, difficult to determine which is to blame because it likely will not show up on a bench test...replace both. Post back with you chassis' ID numbers and i'll provide the part numbers you need and you can get them from your local independent MTD dealer.
Old 04-14-06, 10:16 AM
msidan's Avatar
Hi,
under the seat of my mower there is a sticker that says LOT/MODEL and under that is this number: 137-642-135/3z459. underneath that number is this number: E1B7C.
I hope this helps.
Old 05-02-06, 05:20 AM
msidan's Avatar
I installed a new solenoid (for less than puey61 quoted) and it works great now (does'nt stick). Thanks for all your help
Old 05-03-06, 12:35 AM
cheese's Avatar
Glad we could help, and thanks for the update!
