25mm blade adapter for briggs 6.5
Old 04-15-06, 06:35 AM
I
Hi I need a 25mm blade adapter for a Briggs engine. I is number 123K02-0498 E105011357. I SEE THAT BRIGGS MAKE A COUPLE DIFFERENT ENGINES WITH 25 MM SHAFTS. 123K02 series 0025, 123607-0157,125K02-0303, BV6LM-253532.
I am trying to find out what mower manufacturer uses one of these engines on there mower. I can't find any aftermarket adapters 25mm that are for a keyed shaft. They are all splined. If I could get an original part I could get it machined if I had to to fit deck of craftsman mower.If anybody has any ideas they would be greatly appreciated. Thanks Denny
Old 04-15-06, 09:29 AM
puey61's Avatar
I remember about three years ago or so I was i a similar funk. I believe I found one that was used on a Craftsman walk-behind mower powered by a Honda engine. Go to your local Sears with a measuring caliper in hand and measure the cranks on Honda powered units and use one of these units as a basis for the model number to do a parts look-up. You will likely then have to use one of Sears blades of the length you need in order to match up to this adapter.
Old 04-15-06, 11:45 AM
I
Thanks for the reply. If it works I owe you a steak dinner. I have been going crazy over this deal. The mower is my daughter's. I probably should have just gotten a new mower. I will check that out. Thanks Denny
Old 04-16-06, 11:49 AM
I
Hi again, Just went up to our little Sears store and they dont have any Craftman mowers with the Honda engines in stock. Does anybody else out there know what size shaft is on the Honda engines or any part numbers for blade adapters that would fit on a 25mm shaft. Thanks
