MN
04-16-06, 06:42 AM
Sears Craftsman Bushwacker
I have a Sears Craftsman Bushwacker with 21cc engine and 22" bar. Its about 6 years old and until now has had no problem. It ran perfectly the last time I used it last fall.
Today when I went to start it for the first time this spring, the pull rope wouldn't move. Do you think the engine is seized? If so, what can I do about it? Also what else may be the problem? I pulled the plug to see if it was causing an obsruction and tried the rope again. No change, still locked up. Your help would be much appreciated. Thanks
AL
04-16-06, 09:00 AM
Another thang that I have found in working on theese is bolts and or debres stuck in between the coil and the flywheel,or the starter rope itself wraped around inside.Take the 4 screws out (two longer & two short) and inspect.Be sure to put these screws back in the same places (long screw,short screw,it does mattter).
Reply back on updates or more problems/questions
