push mower revs then sputters and finally died?
Old 04-19-06, 02:01 PM
I have a 20'' Murray Briggs & Stratton 3.5 hp push mower. I have been mowing for several weeks this year without any problem. Today, after mowing for about 20 minutes, the mower started to rev then sputter. I shut it off and put on a clean air filter. Still same problem so I put in new spark plug. Again, engine revs then sputters. I tried to finish mowing but eventually the mower just died. I tried to start it again but nothing. I waited a few minutes then tried to prime it again and still nothing. When I try to prime it, I don't feel any gas in the bulb as I prime it. What gives? Thanks.
Old 04-19-06, 02:22 PM
okay, solved the problem with the gas in the primer bulb - I was out of gas. Next time, I'll check the obvious. But it still revs and sputters while it is running. Any ideas. Thanks.
Old 04-19-06, 08:58 PM
v8driver's Avatar
I have that exact same mower.... 20 inchers are getting hard to find too... make sure the windvane governor linkage isn't binding, and the springs are still good and springy (not a real good way to tell on the springs) I'd also take the tank and carb off (comes off as a assembly anyway) go ahead and replace the diapragm/gasket (very cheap anyway) and clean the pickup tube at the bottom (theres a mesh screen down there) and just spray it out through any and all holes you see good, and rinse the tank out with a little gas.
just to be sure, is this a classic? They did make a 3.5 briggs quantum.
