Craftsman Push Mower deadman switch
Old 04-20-06, 06:04 PM
D
I have a push mower that will start if I spray starting fluid into the carberator but it will not continue to run. I suspect that the problem lies in the dead man switch but I don't know how to test it. Any suggestions?
Old 04-20-06, 07:50 PM
G
Received 2 Upvotes on 2 Posts
Since it starts when you use starting fluid, it is not the switch.
You might want to re-post this in the Outdoor Power Equipment Forum.
I suspect that your carb is gummed up and needs a thorough cleaning.
Old 04-21-06, 04:59 AM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
May simply be fuel supply to the carb also. You might take the fuel line loose at the carburetor and make sure you have flow; after that go inside.
Old 04-21-06, 11:02 AM
v8driver's Avatar
Yes, that means its not the switch... as the switch would cut the spark.... and wouldn't run. You either have trash in the carb, or its gummed up..... either way after you make sure the fuel supplys good... take it off and get a gasket kit, tear it apart and soak it in carb cleaner and blow it out with the cleaner and put her back together and try her then.
