Cub Cadet 1170 won't start
Old 04-21-06, 10:55 AM
Please help, I have purchased a used cub cadet 1170 from and auction. I have tried to get it to start but have not been able to. I replaced gas and plugs and tried to start but will only turn over until battery dies. Tried starting fluid but it just pops and shoots out flame. Any suggestions to how I can get started.
Thanks
Old 04-21-06, 11:12 AM
v8driver's Avatar
The popping sounds like its getting atleast some spark but probablly weak... I'd still check that.... also don't keep turning it over or you might burn up the starter. Auctions mean trouble to me.... You probablly have a gummed up or full of trash carb, which would require a rebuild wil a rebuild kit, soak in carb cleaner for a few hours and compressed air to blow it out good. I'd also check the compression to see what your dealing with.
Old 04-21-06, 11:40 AM
cub cadet 1170 wont start
What would be the best (for a novice)ways for me to check for the spark and compression before I attemp to clean and rebuil a carb?
Old 04-21-06, 08:57 PM
v8driver's Avatar
Take the plug out, put it back into the plug boot.... and ground the threads to the engine and turn it over and watch for a good strong spark.
Old 04-22-06, 12:05 AM
cheese's Avatar
Received 131 Upvotes on 121 Posts
What engine brand and numbers is on it?
