woman needs a mans knowhow with stupid weedwacker
Old 04-22-06, 11:37 AM
G
Angry woman needs a mans knowhow with stupid weedwacker
after turning off my weedeater fl 20 cc, later trying to pull start it, the string won't come out.I opened it up, and seems like the screw holding the string from the inside it hitting ...Can anyone help please!
Old 04-22-06, 12:00 PM
v8driver's Avatar
Any warranty on it?
Old 04-22-06, 12:07 PM
G
aggrivating
No warrenty, I either call it a loss or try to fix it myself...No man around here to help.
Old 04-22-06, 12:16 PM
cheese's Avatar
Received 131 Upvotes on 121 Posts
I'm not sure what screw you're describing. The one in the center of the spool? What does it look like it's hitting against?
Old 04-22-06, 01:04 PM
G
me
the screw holds the end of the string to the spool, it hits the two metal levers that can move ...the screw and levers face each other when put back together....if that helps..
Old 04-24-06, 02:12 AM
cheese's Avatar
Ok, I know what screw you're talking about. Problem is, even if that screw was hitting those "levers" (ratchet pawls), the engine would still turn over, and the cord would come out.
With the pull rope assembly removed, can you turn the engine by hand?
