McCullogh MAC 80-SX Trimmer gsa/oil mix?
Old 04-22-06, 07:19 PM
sod
sod is offline
Today I bought a used MAC 80-SX sting trimmer for my son who just bought his first home. The owner's manual say that the gas/oil mix should be a 20:1 ratio if you are using regular two cycle lubricant and not using McCullogh' custom lubricant. Can this be for real? I have never heard of a two cycle engine that requires a 20:1 ratio. The most I have ever heard of is 32:1, and even that is rare, with 40 to 50:1 being the common ratio. Can someone confirm the 20:1 ratio for this engine. Thanks
Old 04-22-06, 07:54 PM
A
Received 3 Votes on 3 Posts
oil
Many manufacturers recommend that you use twice the oil if you don't use their oil. If you use a high quality oil(Husky, Stihl, Echo...)use it at 40:1. There are many older engines that use 16:1.
AJ
Old 04-22-06, 08:23 PM
v8driver's Avatar
Yes thats a load of bull... then when it won't work, they might ask you if you were using they're oil, and when you say no then they blame it on what you were using. You can use any 2 cycle oil designed to be used in air cooled 2 cycles. 40:1 is fine...
