Briggs spark plug
Briggs spark plug
What is the equalavent Champion, Autolite etc for a Briggs #298809 spark plug?
official equivalent for 298809 is Champion RCJ8
but all Briggs except Vanguard models use Champion J19LM.
The only difference is the Champion RCJ8 uses a 3/4 wrench to tighten, and the J19LM and RJ19LM uses a 13/16 wrench to tighten.
If you can't find a RCJ8, use a J19LM. It should work the same.
J19lm= Bantom height, "19" in the heat range, & 14mm special for lawn mower.
The 2 plugs are totally different in construction & heat range. Champion plugs, the higher the number, the hotter the plug
Received 2 Upvotes
Assuming you have the owners manual that came with the engine and the part number you gave is out of the manual and based on what I believe you have for an engine (single cylinder, vertical shaft, flat head) then you would use a Champion RJ19LM or J19LM. The "R" indicates Resistor and is only required if you live in Canada.
