3.5 HP B&S Timing
chedud's Avatar
05-05-06, 04:23 PM   #1
3.5 HP B&S Timing
I just rebuilt my lawnmower motor but did not check for timing marks when I took the cam out (I know...next time I will). There is a dot on the crank gear and a groove on the plastic cam gear. I lined these up but it will not run!!! Any ideas?
v8driver's Avatar
05-05-06, 07:26 PM   #2
Have you made sure the valves are operating correctly? Hows the compression? Was the flywheel key replaced with a oem key and tightened down to spec?
repair_guy's Avatar
New Member
AL
05-07-06, 03:19 PM   #3
I agree with v8driver,if you got the timing marks on the cam and crank lined up together and a new flywheel key,check youe valves.If you getting good fuel intake,compresssion,spark and exhoust,it should do something.
