Metal to metal sound
Old 05-06-06, 08:30 AM
michaeljp86's Avatar
I have a craftsman 3.8hp tecumseh and it seems to run OK but when you shut it of the engine stops quickly and you hear a scraping sound. I looked and the blade isnt hitting anything. Also by spinning the engine by hand you can fell and hear a scraping like metal to metal about once every revoultion. What is causing this, it doesnt sound good. Thanks for everyones help.
Old 05-06-06, 11:20 AM
daswede's Avatar
Check mesh screening on flywheel housing. Might be bent,or some junk got between screen and housing.
Old 05-06-06, 05:08 PM
JLOpower's Avatar
Does this engine have a blade or flywheel brake? It sounds like you may be hearing it engage.
Old 05-06-06, 07:32 PM
I never thought of that but I dont think it does, I will look tomarrow.
Old 05-08-06, 12:51 AM
cheese's Avatar
JLO is on the right track....the pad is worn down on the engine brake and it's scrubbing.
Old 05-08-06, 09:35 AM
I played around with it and it seems to have something to do with the break. I didnt take it apart to look at it, Last year it was very quiet. I take it that this will need to be replaced?
Old 05-09-06, 01:32 AM
cheese's Avatar
Yep, it can ruin the flywheel.
