Craftsman Lawn Mower - not enough power
Old 04-27-06, 11:09 AM
Hi,
I have Craftsman Lawn Mower. few weeks back I took its engine apart to clean it becuase it just would not start. I cleaned it and after assembling it back again it started working fine.
But I noticed two things that I didn't see before taking it apart.
  1. Before when it was working properly, all I had to do was to push cold-start primer five times, pull the cord and then mower would start and won't die. Now after reassembling it again, I had to push cold-start primer five times and then keep engine on full throttle for about a minute and half. Other wise engine dies. It seems that now engine won't sustain speed if it is not warm enough.
  2. It also seems that power of mower has gone down. Now if my grass is 2 inches tall or have think grass, engine just dies. This was not a problem before.
It is entirely possible that while assembling it back again I might have assembled it wrong, but I am not able to figure it out. Can anybody give me some insight into what might be happening?
Old 04-27-06, 11:26 AM
v8driver's Avatar
What brand engine are we dealing with here? It sounds like you didn't get the carb good enough, try taking it back off and blowing it out again with carb cleaner, even with compressed air. Are there any adjustments to be made to the carb?
Old 04-27-06, 05:34 PM
JLOpower's Avatar
Two things to check: Govenor linkage reinstalled in the correct holes? Carb mounting gasket in good shape?
Old 04-28-06, 12:10 PM
Air leak around carb. Something to do with the induction is leaking air.
Or, possibly, you just need to adjust the carb. Sounds lean to me.
Old 05-01-06, 10:03 AM
arex's Avatar
Originally Posted by YogiWatcher
Hi,
I'm having this exact same problem with my Tecumseh-based Craftsman mower...I keep looking funny at the governor linkage, but I have no manual or other example to look at to make sure I put it all back together properly.
Old 05-01-06, 10:36 AM
I think that's where my problem is too. But I think there is something else is going on too. So I am going to clean the carburator, and check the linkage. I do have manual. I will look into it to see if it gives linkage positions. IF not then I will just go to store and see one of the existing engine and see how it is placed.
If I find something I will let you know about linkages.
Old 05-07-06, 04:27 PM
lexmarks567's Avatar
not enough power
do you know how to rebuild the carb if that is the problem remove it and send it out to me i will send it out to be rebuilt for about $40 this includes parts and labor and shipping PLEASE INCLUDE THE ENGINE NUMBERS WITH THE CARB PLEASE SEND A MONEY ALONG WITH THE CARB EMAIL ME AT [email protected] for mailing address.
