only runs when primer bulb is pumped-mower
troyandmarsha's Avatar
05-09-06, 06:41 PM   #1
troyandmarsha
old craftsman push mower... 3.8hp 20"cut
it ran fine last year until i washed it off.
now it only runs if i pump the primer bulb once started.
i took the air cleaner off and tried it, that didn't help it.
any suggestions?..... thanks.
v8driver's Avatar
05-09-06, 07:00 PM   #2
Sounds like you may have gotten water in the carb. I'd try a quick carb cleaning, take it off and apart and blow it out (through any holes you may see) with carb cleaner and compressed air.
05-09-06, 07:04 PM   #3
troyandmarsha
thanks
.....will try that......
