Anyone use liquid gasket in place of paper gasket?
Old 05-09-06, 09:38 PM
P
Question Anyone use liquid gasket in place of paper gasket?
Hi All, have a green machine trimmer, head gasket broke when taken apart, would like to use liquid form a gasket.
Will there be a problem running or starting as the liquid will not be as thick as the paper gasket thus leaving less room for the spark and ignition?
Old 05-10-06, 12:58 AM
cheese's Avatar
I wouldn't reccomend it, not only because of the thickness but also because of the heat that it will be exposed to. If you can't find an OEM gasket, you could cut one out of gasket paper.
Old 05-10-06, 09:32 AM
P
Thanks Cheese, thats exactly what I needed to know, it was hard finding that answer off google as it gives so many general answers. Cheers
Old 05-11-06, 02:18 AM
cheese's Avatar
Glad to help. Also note that you should try to match the thickness of your original gasket as closely as you can if you have to cut your own.
