running on one cylinder
Old 05-13-06, 03:35 AM
mrkg
wiil it hurt to run twin cylinder engine on one cylinder? really need to mow before i get fixed.
Old 05-13-06, 07:24 AM
JLOpower's Avatar
The unburned fuel will cause problems. Just forget about limping it along on one cylinder. Get it fixed.
Old 05-15-06, 10:18 AM
mrkg
thanks a lot
Old 05-15-06, 03:14 PM
puey61's Avatar
Yes, you should fix it first. But, you can run it as is. You will not cause any harmful damage. You will merely send unburnt fuel through the cycle. You will likely create excessive carbon build-up in the suspect cylinder's combustion chamber. And, you may hear a bang ocassionally when the fuel hits the hot muffler. If the muffler is in rough shape, the explosion of fuel could rip the muffler apart. Obviously, you will have a noticeable power loss.
