where to buy carb cleaner
Old 05-19-06, 03:20 AM
lexmarks567's Avatar
where do i buy carb cleaner and how much does it cost and how do i use it do i pore it in to some water and mix or do i use is strate (no adding water) cause i have a carb that had SAWDUST in it and will not put fuel into the engine it will if i spray fuel into the carb by a spraybottle than the engine will run untill i stop the governer plate is stuck would carb cleaner get it carb running or does it need a rebuild.
Old 05-19-06, 04:53 AM
If there's no gum/varnish, all you need is to disassemble carb and wash with fresh gas or solvent. Especially check passage where gas hose attaches to carb and float needle or diaphragm needle. Also blow out all other passages with air.Don't know what type carb you have. Put a few 3/8" nuts in tank along with a little gas, shake gas tank with it removed from engine to break anything loose and rinse out w/ clean gas several times.
Mike
PS: NAPA sells a good carb cleaner. Either in spray can or large can suitable for soaking entire carb.
Old 05-19-06, 11:54 AM
walbro
the carb is a walbro diaframe type and is missing the primer
Old 05-19-06, 06:58 PM
v8driver's Avatar
Spray can or bath? Napa sells some good stuff you soak the carb in, family dollar, wal-mart.... these places sell spray carb cleaner cheap.... gumout is a good brand to use... heck its 2 bucks a can at a family dollar....
Old 05-19-06, 07:16 PM
bath
i have 2 cans of carb and choke cleaner i need the bath kind where just drop the carb in over night.
Old 05-20-06, 07:59 AM
puey61's Avatar
Napa has the best I've found so far.
