oil-gas mix leaking out the exhaust pipe
indiansman2002's Avatar
05-23-06, 04:11 PM   #1
my dad has a MTD yard machine bought in 1996 it has a 18hp Briggs/Stratton engine and he rebuilt the carb and he still has oil and gas mix leaking out the exhaust pipe?can anyone tell us what the problem could be? thank you very much for your time
arex's Avatar
05-23-06, 06:16 PM   #2
Posted By: indiansman2002 my dad has a MTD yard machine bought in 1996 it has a 18hp Briggs/Stratton engine and he rebuilt the carb and he still has oil and gas mix leaking out the exhaust pipe?can anyone tell us what the problem could be? thank you very much for your time
Not familiar with the engine, but I'm very familiar with the problem.
I was mucking out an old Tecumseh engine, and in the process of de-gooping the carb I unknowingly damaged the float bowl needle valve seat...not a lot, but enough to let a full tank of fuel drain into the carb, down the intake, and into the cylinder and crankcase. I replaced the little silicone rubber donut that is the needle valve seat, and everything was happy again.
Chances are you have a similar problem going on...your float bowl is most likely leaking into the carb somehow. DEFINITELY check your crankcase oil, and be prepared to drain and replace it.
cheese's Avatar
GA
05-23-06, 08:31 PM   #3
Does the oil smell like gas? Does the engine smoke?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
05-24-06, 08:30 AM   #4
we drained the crankcase and it was full of oil and gas mix the oil has a strong gas smell in it and it does smoke a good bit and sprayes the oil everywhere when started thanks Arex for the help
cheese's Avatar
GA
05-25-06, 12:31 AM   #5
Don't run it like that anymore until the problem is fixed. Either the fuel pump is leaking fuel into the engine or the carb is still leaking.
God bless!
