06-08-06, 08:29 PM
I have a 6hp briggs and stratton 2 years old. It wont start and fuel puffs out the carb while some times black smoke will puff out the exhaust. The valves seem to be seeting. somtimes the cord will kick back hard enough to jerk the heck out of my hand.
Please Help!
Please Help!
GA
06-10-06, 07:50 PM
Thanks for the reply!
The puffs of air feul mixture are pretty heavy but not a stream, just atomized. No fuel runs out the carb unless I try to start the engine. I opened the crankcase and looked around. The cam, govenour and piston are all turning with no excessive play. I would like to re-do the Timing before I go get a new carb. Do you know how I would do it? I assume there is some kind of marks I need to line up on the crank gear and cam gear while in TDC. My book does not give me the instructions on how to time. Bye the way! The grass blade was beat up really bad. (bent chipped and twisted) The wife must have hit something big and hard. I didnt see anything wrong with the key on the crank for the crank gear.
God Bless you too.
God Bless you too.
GA
06-10-06, 11:08 PM
Witht he bent blade, and the description of the problem, your flywheel key is sheared for sure. That's what sets the ignition timing. There shouldn't be any changes to the inside of the engine that need to be made or addressed.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
06-14-06, 12:04 PM
Turns out the timing gear and the flywheel key were both broken. The cam gear has six dots on it but one dot is in between two circles one looks like a clock and the other has a arrow pointing to the dot in the middle. Common sense tells me this is the dot I want.
Thanks for all your help.
