Lawn Boy Starting Prolem
Old 06-10-06, 04:04 PM
I have a Lawn Boy model 10323, serial number 8939395 circa 1998. I have loved Lawn Boy mowers since the the 60's when I worked for a landscaper. Last spring it gave me a problem, it would try to start, cough or backfire and die. I had it looked at by an "old timer" and he fixed it, a new spark plug and he said he adjusted the magneto gap. Today, the mower started just fine, ran for about 45 seconds, backfired twice and died. I cleaned the air filter, checked and cleaned the sparke plug, even changed out the gas . It still will only attempt to start, it wll sputter like they all do before it accelerates..........but no joy. I am very handy at cars and trucks, but have done very little small engine stuff.....if the magneto gap has gone off again, how do I adjust it.
Old 06-10-06, 05:29 PM
You can adjust the magneto gap by placing two business cards into the space between the flywheel and the magneto. Then you can rotate the flywheel until the magnet grabs the magneto and pulls it tight against the cards. Then you can tighten the bolts on the magneto and when you're done you can rotate the magnet away from the magneto and remove the cards. You may also want to check the flywheel key and make sure it didn't get sheared for some reason.
Christopher
Old 06-10-06, 11:21 PM
cheese's Avatar
Two business cards is too much. The gap should be .010", or close to the thickness of one business card.
Old 06-10-06, 11:47 PM
some of those old mowers,that magetio would get rusty,and you would have to sand it a little..so it would work..or it wouldnt fire.i had one sears mower,years ago,after it set.all winter,you had to take the carb off and apart and clean all the little holes.the mental.would form little barnicles,,and clog everything up.it wouldnt run..the one bussiness card will do the trick..you got to have just that thing gap.where they dont touch
