Running Mower without blade
lexmarks567's Avatar
06-11-06, 08:08 PM   #1
I have a Areins self pro-pelled mower that I got out of the trash and does not have the blade or the pully to make it go forward.I shaft has teeth (or grooves) for the pully and I was wondering if it would ruin the engine if I ran it with out the blade for a minute or 2 just to see if the thing works
Update: I went back and found the missing peices so I will install them and see if it will fire up.
daswede's Avatar
MA
06-12-06, 05:31 AM   #2
More than likely it will damage the mower. I wouldn't do it.
06-12-06, 05:36 AM   #3
Posted By: daswede More than likely it will damage the mower. I wouldn't do it.
Yeah thats why I went back to see if the parts were there. I found the blade the blade adapter (the pully is molded into it) the air filter the air filter cover and the rope handle.
v8driver's Avatar
06-12-06, 05:56 PM   #4
I've run a few briggs engines with no blades for a couple minutes..... just to run em out of gas and they didn't seem to explode.....
marksr's Avatar
TN
06-13-06, 04:46 AM   #5
I agree with V8driver, it shouldn't make a difference if the blade is attached.
retired painter/contractor avid DIYer
James Sanders's Avatar
CANADA
06-13-06, 08:51 AM   #6
running a vertical shaft engine such as lawnmowers without a blade will still run, it is just hard to get them started, because there is no continuing force pulling the engine over (ie. the blade, a belt, etc)
once you get them started, they should run fine, but will be very hard to idle at a slow speed because of no continuing force, so it might kickback or backfire
that is what i've heard on these forums a long time ago
mikesmalleng's Avatar
06-25-06, 01:53 AM   #7
This is called no load speed
