homelite 2 cycle primer bulb no gas
Old 06-12-06, 07:10 AM
Smile homelite 2 cycle primer bulb no gas
i have a new homelite blower the rope broke and i replaced the rope it started on the first pull after i went through the starting procedure. prime pull half choke run full open.the fan blade came off.now it will not start after i put the blower fan on. it is getting spark but when i pump the primer bulb no gas comes anywhere. when i take the hose off from the primer bulb there is gas there.there is compression to but it won,t even run when i put gas in the spark plug hole. thanks ted
Old 06-12-06, 10:48 PM
cheese's Avatar
When the fan came off, I just imagine the flywheel key may well have sheared throwing the timing off.
Old 06-13-06, 01:22 AM
Bigwind's Avatar
I'm sure a new key will solve the problem! If gas remains a problem check the fuel lines at the primer bulb. IF YOU REMOVED THEM earlier you may have reversed them while repairing?
Old 06-25-06, 03:10 PM
mikesmalleng's Avatar
On the Homelite hand held blowers, the flywheel key and the flywheel is one unit. Most likely the key sheared but the complete flywheel will have to be replaced.
