Pressure Washer
Old 06-20-06, 04:09 PM
Pressure Washer
I purchased a Sear 2000 psi pressure washer last year. When I pulled it out of the shed this year and hooked it up to the waster supply it simply runs out the release value.
How do I fix this?
Old 06-21-06, 01:17 AM
cheese's Avatar
Release value? I'm not sure what you're talking about...the relief valve? I don't see how it could be coming out the relief unless somehow some very high pressure occurred in the pump. Could it be coming out the siphon nipple?
Old 06-21-06, 03:13 AM
It's the mechanism that prevents the engine from overheating. It automatically releases the water to prevent damage.
Old 06-21-06, 05:14 AM
Pendragon's Avatar
Pressure washers use the water they are pumping to cool the pump.
There are bypass guns that allow water flow at a much lower pressure when the gun isn't being used, some have a valve on the pump that does essentially the same thing. Some pumps have neither, and are directed to not run the washer for more than a few minutes unless it is being used.
I would venture a guess that some critter has built themselves a nest inside the pump, dirt dobbers/wasps nest are suprisingly strong when the opening is a small.
Old 06-21-06, 05:40 AM
daswede's Avatar
If you live in a cold part of the country leaving the washer in the shed is not a good idea.Any water left in it will more than likely freeze and crack the components.
