cfaftsman rider blade replc.
dayhawk's Avatar
07-09-06, 08:25 AM   #1
The question is does Craftsman use helicoil inserts as threads for the bolts that hold the blades tight.I am unable to tighten one blade completely.How are the insert removed?Will I need an extractor or is their a technique trick?
hopkinsr2's Avatar
Non-US
07-09-06, 05:12 PM   #2
As far as I know, Craftsman doesen't use any "helicoils" & I don't know of any tools to remove them. If the threads that hold the blade on are stripped, replace the shaft or tower, before someone looses a foot
cheese's Avatar
GA
07-10-06, 01:27 AM   #3
Correct. No mower companies use any sort of helicoil to make threads in the blade jackshaft. A helicoil is a repair type of device. Not reccomended for repairing blade bolt holes either. You can just replace the jackshaft for about $10-$15 if it is a twin blade deck with the star shaped hole in the center of the blades.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
dayhawk's Avatar
07-10-06, 08:30 AM   #4
Right hand threads
Thanks for the info.I am trouble shooting for my dad who is in another city.Yes,it's a 42" cut,twin blade Craftsman.Are both blades held with right hand threads?
cheese's Avatar
GA
07-10-06, 12:35 PM   #5
Yes, regular right hand threads. I think it's a 3/8" bolt probably 24 tpi threads, around 1 1/2" long.
God bless!
dayhawk's Avatar
07-10-06, 02:19 PM   #6
blade bolts
Thank you.It was not the bolt hole but the bolt itself.Friction had worn the top 8-10 threads smooth,thus the looseness.A new bolt was all that was required.
cheese's Avatar
GA
07-10-06, 10:55 PM   #7
Great! Glad you got it fixed!
God bless!
