craftsman leaf blower only runs at half choke
Old 07-09-06, 05:27 PM
lexmarks567's Avatar
In a collection of mowers that a guy droped off for me to fix and resell or keep was a craftsman leaf blower/vac/mulcher its 175MPH.Don't know the model. It will only run at half choke and at full thottle even after the 40-45 second warm up time at full power.As soon as I let go of the throttle it dies it makes no attemp to idle. And if I put it to run(no choke) it dies.What do you think before i pull the carb off.I prime it 8-10 times like it says.As long as its a half choke and full thottle it runs. Let off the throttle it dies.Any adjustments that need to be made.
Old 07-09-06, 05:54 PM
sod
sod is offline
Replace the diaphram. I have 200mhp craftsman blower with the same problem and it was the diaphram. Easy fix thanks to this board's expertise
Old 11-13-06, 02:26 PM
Have the same problem
Is there anywhere where you can obtain a manual for this blower? Also, where would you get parts?
cjartist
Old 11-13-06, 03:49 PM
Azis
You will need a model # and then go here http://www3.sears.com/
for parts listing. Sears also sells parts but may be purchased for less from other sources.
