Craftsman mower (replacing flywheel)
stamperdawgman's Avatar
07-16-06, 04:59 AM   #1
I have an old Craftsman riding mower with a 12.5 hp Briggs&Straton moter that has a plastic flywheel and plastic starter gear and both are getting mangled, but I dont know how to get the flywheel off. Thanks for any help.
snoman's Avatar
CANADA
07-16-06, 05:54 PM   #2
stamper
I don't recall ever seeing a plastic flywheel but I've heard of composite material for the ring gear and plastic starter gear. If you could post the model,type and serial number of the motor we can see what needs to be replaced. Also Briggs sells flywheel pullers for all their models.
snoman
cheese's Avatar
GA
07-16-06, 08:18 PM   #3
You can go to autozone, and rent a steering wheel puller and bolts, and pull the flywheel with that. You can buy a replacement ring gear made of aluminum. The flywheel is cast iron. Use the bolt holes thet the fan bolts go in to pull the flywheel with the puller bolts.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
