Montgomery Ward/Yard Machine 18.5 B&S no start
nova22079's Avatar
07-18-06, 08:17 AM   #1
I just picked up a Montgomery Ward (Yard Machine) Powrcraft lawn trator (Model# 134Q699H088 / TMO-340005) with a 18.5Hp B&S engine. I put in a new battery (i got it without one), turned the ignition with the PTO disengaged and clutch pressed down, and nothing happened. I did jump the starter from the battery and the engine did turn over, but did not start. I pulled the plugs and checked for spark, but got nothing. Tested the spark plugs on a Toro lawn mower and both worked.
So, I'm guessing I may have a bad solenoid with the key ignition, but have no idea what's causing the no-spark problem when I jump start the engine.
cheese's Avatar
GA
07-18-06, 09:53 PM   #2
If the safety switches are not functioning correctly, it could possibly cause both of your problems. Check the switches out. You can disconnect the single black wire coming from the coil and check for spark then. If you have spark, there is a problem in the mower harness. If not, the coil is bad, or the engine is turning too slowly.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
nova22079's Avatar
07-19-06, 04:49 AM   #3
Thanks for the advice. As it utrned out I checked the fuse, it was blown. I replaced it, turned the ignition and it fired up.
I must have blown the fuse while jump starting and never bothered to check it afterwards.
cheese's Avatar
GA
07-19-06, 09:02 PM   #4
Glad you got it. The fuse won't cause it to not spark, but maybe it wasn't turning fast enough to spark when you were jumping it.
God bless!
