John Deere / Put In Gear & Won't Move / Help !
Old 07-19-06, 07:30 AM
Question John Deere / Put In Gear & Won't Move / Help !
Good Day All,
I have had a GREAT day thusfar !
I changed a flat tire this morning on my 4 month old John Deere L102, I put the tire back on now the dam thing will not move no matter what gear I put it in !
Any Idea's WTH is wrong with it ?
Sorry for the emotion, I hate to pay for quality & then it fail me.
Please help as soon as possible.
Thank You
Old 07-19-06, 08:08 AM
bontai Joe's Avatar
When you removed the tire, did you loose the key that holds it to the axle to prevent the axle shaft from rotating inside the wheel hub?
Old 07-19-06, 08:37 AM
No, I just went back out and looked at it again.
The driveshaft looks fine, the axle is turning, but the mower is not moving.
I guess I will go back out and take the tire completely off again and reset it.
Maybe I am misaligning something, somewhere ?
Thank You for your reply, I appreciate your help.
Old 07-19-06, 10:03 AM
Check your owner's manual. I suspect a transmission lockout lever, which allows you to push the mower with the engine off.
On the LT160, it's on the back of the mower, between the seat and the hole where you would attach a trailer. Just look for a rod sticking out, and push it in.
Old 07-19-06, 08:48 PM
cheese's Avatar
If it moved fine before, and all you did was pull the wheel off and put it back on and now it won't move, then you lost the axle key. I see it happen all the time. The axle is keyed to the wheel. There is a slot in the axle, and a slot in the wheel, and a key that goes in it. If it falls out when you remove the wheel, the axle just turns in the wheel and the mower goes nowhere. I don't think quality is the issue here.
Old 07-25-06, 09:34 AM
Smile
It was the key guys, I did not pay attention when I pulled the tire off.
I will most likely sell the mower even though it is brand new, I need a little bigger model,
Moderator note: Sorry Cat but that's considered an ad and is not allowed in the forums.
Old 07-26-06, 08:43 PM
cheese's Avatar
Glad you got it!
