vertical engine for go kart?
Old 07-22-06, 09:53 PM
is it possible to have a vertical engine put on a go-kart with a pulley? if so, where could i find these certain pulleys?
Old 07-22-06, 10:10 PM
lexmarks567's Avatar
Depends how is it going to be mounted.You can't mount a vertical engine horazontally as you will seze the engine cause the oil won't be able to protect the engine. In fact I don't think it will even start.
Old 07-22-06, 10:48 PM
James Sanders's Avatar
you'll probably need a transmission. it'll convert the vertical motion to horizontal motion.
Old 07-23-06, 09:15 AM
What engine are you working with? The crank shaft diameter at output will determine a lot of things for you.
Hope this helps
Old 07-23-06, 01:28 PM
its a 7hp motor, its from a friends lawnmower.
Old 07-23-06, 03:35 PM
If your are doing this just to see if it can be done I would suggest that you check out the workings of a few different self-propelled mowers since they have vertical engine and drive the wheels, you can then get some ideas how to make it work in the same or similar way. I think some of the older Snappers were 5 ot 6 speed. Have a nice day. Geo
Old 07-23-06, 04:41 PM
ok, thanks for the info
