cyntrifical clucth?
jarhead's Avatar
07-28-06, 09:50 AM   #1
cyntrifical clucth?
have this project go-kart, got the engine running good, now have this other problem. it has a cyntrifial clutch on it and i dont have a belt for it, what does this do and where can i get a belt for it.I cant find any info on this.Is this a special type belt or can i use a automotive type belt in its place. how do you measure for the fit?
jarhead's Avatar
07-28-06, 10:25 AM   #2
I posted wrong its a torque converter, not sure how this works. does this require a speical belt? how do I measure for correct size? will an automotive belt work in its place?
marbobj's Avatar
IA
07-28-06, 10:54 AM   #3
Posting regarded a centifugal clutch assembly - wrong part.
cheese's Avatar
GA
07-28-06, 04:21 PM   #4
Probably a clutch made by Comet. If you can find the clutch numbers (I think they're stamped on the bell shaped piece on the engine part of the clutch), you can match a belt to it from a book or online. You'll have to use a comet belt. There are no other belts that work with this system...it's a special belt. It is a centrifugal clutch. It's also a variable drive.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
jarhead's Avatar
07-31-06, 05:34 AM   #5
Thanks Cheese, your a big help, will check this out and post back later. got some other things going, this is going on the back burner for now.
99venomsvt's Avatar
08-07-06, 12:29 PM   #6
Check out this website for all your comet belt needs:
http://www.gokartsupply.com/tcbelts.htm
Check ouy these websites for any thing else:
http://www.mfgsupply.com
http://www.gokartgalaxy.com/
jarhead's Avatar
08-07-06, 12:57 PM   #7
thanks 99venomsvt, BIG HELP! this go cart i was working on isnt mine i just got it started. engine runs fine just needs a belt and some final adjustments, problem is there saying go a head and get the parts, but dont want to put the bucks up. anyway i love to get info that can be useful down the road. again thanks
